- Thank you received: 1
Cummins ISX CM570 Fan Clutch ECM issue
- Luis_Armstrong
- Topic Author
- Offline
- User
Less More
2 years 2 months ago #34 by Luis_Armstrong
Cummins ISX CM570 Fan Clutch ECM issue was created by Luis_Armstrong
Hi,
I have an ECM from Cummins ISX CM570, PN. 3408426 which has an internal issue with the Fan Clutch output at pin number 5 in Actuator connectors. Fan clutch status parameter change as expected when is manually activated or by coolant temperature but there is no electrical output.
I've tested with other ECM and same configuration getting success, so the issue is the ECM under question. Does anyone have information about the mosfet location in the circuit board. I opened the ECM but there are many drivers, maybe injectors and engine brake, but I'm not familiar with the location of each component.
Thanks for your support.
Please Log in or Create an account to join the conversation.
- narkeleptk
- Offline
- Moderator
Less More
- Thank you received: 10
2 years 2 months ago #35 by narkeleptk
Replied by narkeleptk on topic Cummins ISX CM570 Fan Clutch ECM issue
Please login to view the answers
- Luis_Armstrong
- Topic Author
- Offline
- User
Less More
2 years 2 months ago #36 by Luis_Armstrong
Replied by Luis_Armstrong on topic Cummins ISX CM570 Fan Clutch ECM issue
- narkeleptk
- Offline
- Moderator
Less More
2 years 2 months ago - 2 years 2 months ago #37 by narkeleptk
- Luis_Armstrong
- Topic Author
- Offline
- User
Less More
2 years 2 months ago #39 by Luis_Armstrong
The following user(s) said Thank You: narkeleptk
- narkeleptk
- Offline
- Moderator
Less More
2 years 2 months ago #40 by narkeleptk
Time to create page: 1.289 seconds
